Massimo Msu 500 Has No Power
Popular Now
By Hoppy one
I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
By Eman85
By Jeff freeman
I have a Coleman 550. Was having problems to start with where it would start and then shut off after a couple tries. It would take off and be good. It then got to a point where it would not start at all. I replaced the fuel injection twice the second time I replaced it I noticed a mouse or something had chewed one of the wires that connect the electrical to the fuel injector. . So two-part question first does anybody have a part number for that wire harness? Second, any other ideas after I fix the wire harness permanently on what could keep it from starting I have gas flow up to the fuel injector.
By JohnnyB
My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
