Side by side mirrorsKemimoto
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
By Felderlostnspace
2016, Hisun 500 turns over great but Spark plug is firing when I turn the ignition key on. I’ve got good fuel pressure to the injector. Pulled plug out and it is wet with. gasoline. Air filter is clean. Turns over great just does not even try to pop or start.. I’ve checked off uses and they are good when I turn the key on I’m getting power to the injector.. I’m not hearing the injector pulsing, but may just be my hearing.. With the spark plug getting wet with gas I feel like the injector is pulsing and spraying. Any suggestions would be great. I don’t know the hours on the unit offhand, but it has 600 miles on it. Thank you for your comments and advanced.
By Jacob E freeman
By Dave egger
Hello. I need some help. I have a 2015 Polaris rzr 1000. I was told the clutch was bad so I put a new one in with a new belt and having the same problem. It won’t go over 55 mph and it takes forever to get to that speed. It also will not go over 6600rpm and it also takes forever to get there also. I’ve taking it to the dealership and had them look at it and they said they can’t find the problem. I’m at a loss. Has no check engine light at all. If someone could give me some ideas or has had this problem it would be much appreciated. Thank you Dave.
By Easyrider
I have a 2015 Hisun Strike 1000 I’m having overheating issues, but mainly when I’m going downhill when I’m going uphill or on the flats, it seems to be fine. I have bled the bleeder’s to get the air out. Also when it is overheating, the oil light seems to come on. does anyone have any advice?
Also, off-topic a little does anyone know where I can find a windshield for this unit any help would be appreciated
