I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
Here are a few specific questions about them
1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
2. If you had one and got rid of it, what was the reason?
3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
1.  No not reliable.  Yes, bad seal that leaked oil on drive belt, replaced seal and belt and misc clutch parts.  Shift ball detent, both when new.   Actually parts have not been the problem, quality is the problem.
2.  Have not got rid of it, no one wants it.
3.  Kubota Sidekick
4.  Damm near impossible, some parts are on ebay.
Mine is a MSU500 bought new from Tractor Supply.
Hello
i have a 2022 Massimo t-boss 550. And it suck’s! I’ve blown 3 clutches 1 was my fault. The starter bearing (clutch). And now I’m dealing with timing and valves. Once you get the bugs out and know what it can’t do it’s ok! And no service. The one person that did help me at Massimo Canada got fired. Lol I’ve been fixing mine since I have no money to buy anything else, by the time I’m done with it it should be ok. I hope lol
good luck!!
  • Sad 1
Do Not Buy Massimo...  bought one new from Tractor Supply..   Overheated on first day in first mile.. Tractor Supply refused to help, Massimo would not pay for repairs.. Refused to do anything. It went in the only shop I could find in my state that will even work on them, 6 times in first year.  Head Gasket failures.. Cracked head.. ............They worked on it, but you must pay cash, Massimo has stiffed every shop around. When I called BBB on them, there were hundreds of complaints.. I threatened suit, rep laughed on phone.. said..wont be the first one!............Trust me when I say... DONT BUY MASSIMO!
I see a couple of these folks posting have the old Hisun models, hey Joe!
Read much about them and it won’t take long to figure out they sucked. I have had only two issues with mine and one was caused by bad gas. Drained the tank and everything was fine again. Getting the shifter to smooth out was the only real issue. I’ve been able to get parts like plugs, filters and injectors with no problems.
20 minutes ago, Joe Breaux said:
Good morning.  How's it hanging?  I'm. Fishing in the Basin.  LIFE IS GOOD
Hasn’t been warm enough up here for much fishing, but it’s changing today. Hope you didn’t get any damage from that last storm.
DON'T BUY A MASSIMO! The quality is soooo bad! I have a 2021 550 TBoss new when inventory of the decent brands was at rock bottom. I paid new what used decent brands were selling for. I quickly learned why. The quality is soooo bad. Out of the gate I had to make numerous adjustments to get it to run, drive and operate smoothly. Couldn't tow anything because the hitch receiver snapped off, the cheap plastic guards in front of the suspension parts broke off in no time, flooring cracked after a bit of use, windshield is now un clear and unusable after cleaning a couple of times (yes, I was extremely gentle), And all of the above and more on a machine I barely use (very low miles)
I would love to sell it and buy a good one some day but I don't think anyone would buy it.
Listen to all of the advice above and stay away from this brand!
  • Thanks 1
85 today. Bass are spawning ..no damage at home or Whiskey Bay camp
    • By Rschrem
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
    • By Pick a name
      The Axis 500 will not shift into low or reverse.  I have high when it should be in low and all the other places it is reverse.  The gears in the shift cover are fine and I shifted it when the cover was off and yet no change (so it can't be the shifting mechanism gears).  I t has been difficult to get it into low for awhile.  But now it is either high or reverse, no neutral either.
