After market oil filter for 800cc Sandviper?
By Randyh79
Does the transmission share the crank case oil with the engine or does it have its own oil seperate from the engine?
By trevor
my hisun 400 has ben leaking oil out of a small metal tube on the bottom near the oil filter. Got the side by side given to me after been sitting for a couple years but 2 quarts in nothing happened my buddy went and worked on it and put another quart in it. i thought it just pushed out what it didn't need. but its dry as a bone inside. does have a good clatter coming from the top end as well, with oil in it. looking for some help not much on the internet about these things.
By Wesley
I have a 2022 500 Hisun product, I have had them in the past. I change my oil myself and trying to drain through the hole where I remove the plug is a mess. How does everyone keep the belly pan clean during the oil and filter service?
Wes Jackson
By bfairchild21
Please help I have a Massimo 400 buck that has an oil leak. The oil is leaking on the front side of the motor. It leaks out of a u-shaped steel pipe that has two banjo style fittings on it. I have tried using RTV and different banjo washers and have had no luck. It drips about one drip per second while it's running. I can't find parts for it at this time.
By catalyst
We own a 2020 Kubota RTV-XG-850, with only 400 hours on it and it has been at the dealer 3+ months. We were just informed our engine failed and requires a complete rebuild at only 400 hours! There is a loss of compression in cylinder #1, which is causing backfiring and a loss of power. There is also excess gas in the engine oil.
We are just outside of the manufacture's warranty period, and they are serving us a nearly $5000 repair bill, with only a 90 day warranty.
A member at a different forum had the same issue at 22 hours and fortunately, his RTV is under warranty. He was informed that "short tripping" (as Kubota describes it) causes gasoline to enter into the engine oil, which causes a dilution of engine oil and eventually leads to catastrophic engine failure. This killed our engine in under 400 hours!
Is anyone else with a 2018-2022 XG-850 running into similar issues?
