Everythingdunes.com is an innovative and creative new company whose passion is, Literally, EVERYTHING and anything related to riding at the Sand Dunes.
Based in the Pacific Northwest, everythingdunes.com is moving ahead at full throttle creating unique products, such as infant onesies, toddler t-shirts and gift bags. Fueled by a family tradition of quads, dirt bikes, [...]
View the full article
    • By mike28honda
    • By MilSurpYinzer
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
