Trooper owners in Kentucky.
Popular Now
By rdc
By paul allen
thanks...pa
By KMP
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
By hetovi
Hi everyone,
I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
Are there specific brands or models you recommend for durability and ease of use?
Also, how do you handle cleaning and maintenance without causing damage?
Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
By gridlock
After three years, my Sector completely died. Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged. The batteries weren't charging 100% anymore, so decided to convert to lithium.
As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed. I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly. I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)). Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts. I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
So far, it definitely is better than with the original AGM batteries. Sustains speed better going up hills, and seems to have plenty of reserve current. The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
A few questions:
In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that. Is there any more info about that?
Have folks replaced the onboard 12v battery, and if so, with lithium? I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
Is there a recommendation as far as charging with the lithium conversion? As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time. What do you think?
