Making Changes, new look
It all started when I went to the SEMA show in Las Vegas. If your not familuar with this show, it is for the manufactures of aftermarket products for on and off road vehicles. First I bought a winch. Actually 3 of them. A 12,000# winch wilth synthetic rope for my truck, a 4800# one with steel cable for my Trooper which I will lengthen the drum on so it will hold about 125 feet of synthetic rope while fitting it so it can be used on the front or back as Joyner originally intended for their winches. I also bought a 9500# winch with synthetic rope which I may sell. These are all rated at single line pull. Then while at the show I bought a pair of carbon fibre racing seats. These seats sit far better while supporting and holding you in better. They sit a lot lower so I can now lower my top without giving up all the head room. I'm also going to go with power seats as I can do this easier (just happen to have the drives) and still keep things low and I'll still be 10 pounds lighter per seat. In the mean time I have wanted to go to a glass windsheild. Tried 3 lexan ones and wasn't satified with any of them. The static charge they develope just draws too much dust. I wanted a curved windsheild like one of my designs in lexan. Started to look in auto junk yards at front and rear auto windows. Most everything is too big and pretty much all rear windows have heat wires across them. Got lucky and found a rear window from a 1972 Maverick, just right and no heat wires. Currently I'm putting the seats in which will dictate how low I can go with the roof. The roof heigth will dictate the slope of the windsheild which in turn will dictate the shape of the front portion of the roll bars. I bought some foam pipe insulation from Home Depot to use to mock up various design thoughts for the roll cage. Once decided upon, I'm going to build them using .095" by 1-3/4" DOM tubing alloy 1026. I'm leaning towards a fast back design but time will tell. Because I'm going to have to get into the front fenders, I'm going to extend them forward, tappering them off to no width at the frontl This should eliminate the occasional blow back of sand I get from the front tires.
The timing for this project is working out just perfect as I just had surgury on my right foot for flat feet problems. This will take 6 weeks to heal and then I have to do the other foot. This gives me time during which I really can't ride in anyway. I'll be a bit slow but this project is going to take a lot of time just sitting there and looking at things. Besides as some of you already know, when I'm in my shop, no matter what I'm working on, I'm in Hog Heaven. The final dyno work will have to wait, besides, I'm going to change the pully on my supercharger to spin it a bit faster make up for my lower compression. The compression ended up too low from lowering it before adding the aftercooler which effectively lowers compression.
Sound cool Lenny. You probably already know but only the front glass in cars is laminated so if a break occurs glass will not fly in your face. The rear glass is tempered and will break into a million small pieces.
rocmoc n AZ
rocmoc n AZ
Thanks Mike, I didn't even think of that. Both I and Jeanne wear glasses so hopefully that wil help should should you kick up a big stone as your screaming by me.
Lenny,
You shoulda hollered at me when you were in Vegas... At least could have gone to dinner.... I didn't go to SEMA this year but I did volunteer for the Optima Battery race in Pahrump on Saturday... Man, talk about sights/sounds of those cars from SEMA doing the road course, autox and speed stop challenge !!!
Pure motorhead heaven...........
The race is the Saturday after SEMA... This year they allowed in spectators ($10) ... First week of November is usually the SEMA show... I'll post when
i know for sure...
It should be broadcast on Speed channel sometime this winter too...
Lenny I made mud gaurds from a high impact plastic which I got at SSD plastics, look on their site they work great and are very durable. I had the same problem with dust on my windshield but I was able to solve it with just some good car wax which also gets rid of the smoke look you can get from cleaning it. I just apply a couple of coats a few times a year and have much less dust. My windshield is complete except the top four inches which I cut off so I could keep a good air flow which helps keep the cab pressure the same to prevent a vacum which will draw the dust into the cab. Im out all winter so if it is raining or snowing I made a squirt for the top of the wind shield which is attached to the inside of the roof and snaps up out of the way. When it is bad weather I can unsnap the squirt from the roof and snap it to the top of the winshield to close off the upper four inches of the windshield. When its raing or snowing the dust isn't a problem with the squirt down.
I used 1/8" thick conveyor belting for my fenders. It's very durable and stiff enough to hold it's shape where I have it sticking past its supports. Thanks for the thoughts on the vacume, I have forgotten about that problem. I have a firewwall between the engine and cab. This helps cut down on the air flow thru the cab area. I'll just have to see how it goes after the windsheild is in. In the nicer weather I plan folding the windsheild down when riding. Kind of like the air in my face, sometimes. I do have side deflecters I made a couple of years ago that fit on the vertical side tubes of the windsheild that catch the air and deflect it into the cab area to help break the vacume effect. May have to dig them out if I have a problem. I plan on putting window washers and wipers on so when the window does get dusty I can clean it on the fly. The glass will be more resistant to scratching with the wipers.
    • By RBonds007
    • By Pajer
      Does anyone know where the winch fuse is located on a 2021 ut400? I’ve been working on the solenoid because the winch will only go in one direction..
      Either in or out depending if I reverse the leads on the solenoid. Now I have no power to the solenoid and it appears I blew a fuse. Winch is supposed to have a 30 amp fuse.
      i checked all the fuses in the fuse box near the battery and the 30amp fuse hanging in the compartment. Everything is good there.
      but I can’t locate any other fuses. Any help would be appreciated.
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
    • By LouisC
      Hey there, anyone have any advice on removal of the original winch? Upgrading to one that actually works.
