Three contractors are bidding to fix a broken fence at the White House.
One is from Chicago , another is from Kentucky , and the third is from Iowa.
All three go with a White House official to examine the fence.
The Iowa contractor takes out a tape measure and does some measuring, then
works some figures with a pencil.... "Well," he says, "I figure the job
will run about $900: $400 for materials, $400 for my crew and $100 profit
for me." The Kentucky contractor also does some measuring and figuring, then says,
"I can do this job for $700: $300 for materials, $300 for my crew and $100 profit for me."
The Chicago contractor doesn't measure or figure, but leans over to the White House
official and whispers, "$2,700." The official, incredulous, says, "You didn't even measure
like the other guys! How did you come up with such a high figure?"
The Chicago contractor whispers back, "$1000 for me, $1000 for you, and we
hire the guy from Kentucky to fix the fence." "Done!" replies the government official.
and that, my friends, is how the > new stimulus plan works!
    • By Jeff freeman
    • By Sharon
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
    • By GTech
      I have a 2007 Joyner Commando 650, and cannot find a shift cable. Commando is a 4 speed, and the cable I need is the one to the right side of the shifter if you are sitting in the front seat. Cable is approximately 40", and has an eye on each end. I tried fitting a can-am shift cable, and the ends are just too long to mount and make work. Looking for a supplier so I can get the Joyner moving again with the correct shift cable.
      Thank you,
      Gary
    • By MassimoNeverRunsLife
      2021 T-Boss 410 — and yet another story from someone who bought one brand new without thinking twice about the fact there's no real service department like you'd find at an actual dealership.
      The Problem:
      Around 20mph, it bogs down like it's choking on something. Pedal to the floor, it sounds like it wants to go, but it just won’t. Makes no difference if it’s in 2WD or 4WD—same sluggish result. Reverse works fine. Shifts between 2WD, 4WD, and neutral without issue.
      I’ve searched online but can’t find anything specific that matches what I’m (admittedly) guessing might be wrong. Truth is—I have no clue what the fk the actual issue is, and I don’t have the kind of mechanical memory others seem to when tearing these apart. That said, I’m good with my hands and can follow directions—I just don’t have any clear ones to follow right now. Any help or pointing to the right direction would be appreciated- next closest massimo service center was "fk you" miles away they said,
