old mule power problem 1987
i have an older kawsaki mule 1000 model kaf 450 and i have no power under load and can only get about 10 MPH out of it on flat ground and cant even climb up a hill with it . ive cleaned the carbs out and replaced the fuel lines and filter. anyone got any ideas what might be wrong?
  • 5 months later...
Hey Buckshot,
If you have ruled out everything else that could be limiting the engine speed, and nothing comes up as a problem, go and read a post I just did on carburation problems and my fix. I have found that most of the mysterious running problems are fuel related - that is partially clogged fuel delivery galleries to the jets. This is an extremely common problem that mechanics usually charge large bucks to fix by removing and "boiling out" the carb.
Good luck,
Will
  • 1 year later...
    • By LongSun
    • By Bill12345
      🙂 2022 hot seat Pioneer 1000-5 trail
    • By TomW
      I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good  but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
    • By NDV45
      I have  2008 Cub Cadet Volunteer Tracker.  Was running fine, parked and next morning electric fuel pump inop.  Checked voltage had 4.2 volts.  Swapped relays in fuse box, checked all fuses (good) and still low voltage.   Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
      Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss.  Need Help Please.
    • By htrotte
      Is it possible to add power steering?  If so where do I find parts?
