Hello Guys! I have purchased a 2009 T2 from a member here and it has a issue with it...It will not rev fast at all and it acts like its out of time. I checked timing and it looked good. I tried putting my scan tool on it but it says failed.... I'm pretty sure its a sensor...... The plugs are black coated. If you mess with the fuel pressure it helps alittle but I know thats not the problem........Thanks in advance guys...Oh yeah what engine is this modeled after for parts like the sensors?
Guest Lenny
I would check the oxygen sensor in the exhaust. You could try switching the two sensors but that requires swapping the plugs which wouldn't be too hard. Also look at the map sensor in the intake plentum. If you look on google you can find out how to test these. Your obviously getting too much fuel or not enough intake air. Check your air filter for being clean. Also replace it if it is the stock filter with a K&N filter mounted up high out of the dust area. Most snorkle them up to the roof area. Probably check the Throttle position sensor too. These are the three sensors that the computer is going to look at for determining the fuel required. Your fuel pressure should be around 55 psi. Watch your fuel pressure as you try to rev up and look for any weird stuff going on.
Ok I will check these sensors. Just lost. The filter obviously got mud and water sucked through it so I wonder if it ruined the mass sensor. Do you know what sensors or the motor is copied from? O heard Suzuki and Ford escort......?
Guest Lenny
The Ford Escort is close. It was copied form a european Ford engine that was popular for rally racing there. However it uses a standart engine computer by Bosch or Seimens, can't remember which. I would assume that it looks ofr signals that are standard fior mmost vehicles. This makes me think that most sensors could be adapted into the system and work fine but no guarntees.
No no the cam stopped and the crank kept turning....no marks on belt at least not this motor. I have seen them on belts though...
Thanks bigdan I didn,t think so but I could have missed something.I see you made it here I told you there were more people here that own t2 than on the joyner forum
oh yeah lots more.... I guess us Joyner owners are toopers to stick with and still buy Joyners even though parts and stuff is hard to come by...LOL First look at the one I seen made me want one I think there bad ass! Thanks Plumber!
Guest Lenny
Were are the marks on the timing belt to line up with the gears
There are not any marks on the timing belt. There is a mark on the lower pully that lines up with a mark or small bump on the block. This needs to line up when the mark on the top pulley is lined up with it's mark on the head or head cover. Go to JMCs site and download the manual, it shows the marks.
    • By Nick Varnes
    • By mehe
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
