Hi all, I've searched but can't find the overall size of the trooper. I'm looking at a new trailor (smaller) but the joyner is in storage right now. Just seeing if any one can post width and length of the wheels, thanks!
Rob
Specifications
Model TROOPER
Dimensions:
Overall length 3300mm/130 inch
Overall width 1600mm/63 inch
Overall height 1990mm/78 inch
Seat height 800mm/34.6 inch
Wheelbase 2470mm/97.2 inch
Ground clearance 300mm/11.8 inch
Minimum turning radius 6000mm/236 inch
Basic weight:
With oil and full fuel tank 780kg/1719 Ib
    • By nrggaragebuilds
    • By OBL
    • By Firewalker918
