Does anyone have a stock rear with usable tread left they want to sell? I am laid off right now and I have other things to buy first if I'm going with a new tire. Broke the wire in the bead. Dam hill climbing. Lol
    • By mrpro
    • By Firewalker918
    • By Jeff freeman
    • By Thearm
      I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
