Does any one have one of these they want to part with???
Kinarfi
post-90-0-41135200-1375688778_thumb.jpg Also need the rubber boot for the side with the set screw in the back.
PS One of the arms got bent because one of the bolts fell out and then it would wedge against the wheel and lock the wheel up, to release it, all I had to do is back up a little. Having a wheel lock up while you're travelling down a dirt road at ~ 20 is no fun, but a real adrenaline rush.
Kinarfi - quick fix then it sounds like. Did you get it up and going? Hope so.
I actually bought a new caliper and an extra bracket plus one set of pads and one set came with the new calipers plus I already had 4 sets, so, I have new pads all the way around and on the parking brake, so all is well, put 50 miles on it Sat.
  • Popular Now
    • By Fmaxiron
      Thanks a lot!
    • By paul allen
      thanks...pa
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By John Gubancsik
      After sitting this winter in a garage, I noticed coolant under the side by side when I went to get it out.  Does anyone know what would cause the coolant to leak out while in storage?  Any assistance would be greatly appreciated.
      John
