l Cannot find a fuel pump for my Kawasaki 2020 mule ,it has been discontinued., is there a replacement fuel pump I could use or is one still somewhere I never checked . please help.
    • By Jamie 67
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Kierobi
    • By AaronD1982
    • By RBonds007
