well shit from what i hear he is nt doing them any more and i m going to attempt to fix mine for now i suppose nothing chewed up just could nt get the locker to work due to slop in the gears
well it is all back together the i had to cut the inside off the bolt head to get them to clear but it locks in now and going to have to wait tomm for the lock tight to set up before i put any oil in it and test it
    • By nrggaragebuilds
    • By mrpro
