Are you able to keep your foot stable on the throttle pedal or does it react to the initial rearward surge by depressing the throttle pedal a little more causing it to surge and you pull off the throttle.
Or is it truly mechanical in nature, no matter the throttle setting.
    • By Fmaxiron
      Thanks a lot!
    • By CKfrustration
      I have a Hisun Sector E1 UTV.  Worked pretty good for a while but then started to run into issue with gear grinding noise.  Will not engage in forward or reverse.  When put into forward or reverse and press pedal can hear a whiring noise as if something is supposed to be engaging but is not.  Occasionally it will grab in jolt forward momentarily but then ceases.  No error warnings or codes given.  Due to money restrictions, I really need to fix this myself.  Has anyone had this problem and what could it be that is needed.  Any help is appreciated.  Thank you!
    • By kmiller7351
      Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
    • By JWS
      Help Please!
      Last year my Mule started running bad and was hard to start. NOT a battery or starter problem. I replace the carb with one of those cheap Chinese carbs from Amazon. Problem got worse. So, I replaced the fuel pump, one from Kawasaki, fuel filter and lines. Then replaced the fuel pump line to the engine. Finally bought a Kawasaki carb. Everything was ok till I filled the gas tank with fresh gas then it started running bad and hard to start again. The tank is clean. Gas is fresh, AGAIN. Filter is new. When running it has an occasional misfire. Managed to burn about a gallon out of the tank. Runs better. Replaced the gas cap in case it wasn't venting. No change. When running, if you try to go full throttle, it bogs down. The gas is good. I use it in my mower with no problem. The stater was replaced about one year ago and the flywheel cleaned inside. Still seams like a fuel problem but I'm at a loss. It's going back to the mechanic shop today. We use the Mule every day, live on a farm. It's never sat up. It has 1045hrs on it. New battery and starter.
      Any ideas?
    • By Rusty
      2022 Segway x10. anyone know how to enable reverse alarm? Thanks
