2014 coleman 700 utv starts idles about 15 seconds then dies any thoughts would be appreciated
Ok- here’s a thought. I’ve run into similar situations on outboards. They run when the enrichment loop is active at startup and quit when it kicks out. Backfiring through intake can also be from lean mixture. Put a spark checker on and as the engine dies see if you continue to have spark as it winds down. Now it could also be timing, but if it runs rather normally at idle till it quits I would be less likely to think so. But for the heck of it check the crank position sensor. Good luck. Keep us posted.
Pop Bob
  • Popular Now
    • By AaronD1982
      New starter solenoid....check
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Burk
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By AaronD1982
