Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
Replaced injector and it has been running well until yesterday. Now it’s cutting out again mid throttle when it gets up to full temp. Possibly misfiring too did smell some unburnt fuel at one point when it would cut out.  Light throttle or flooring it and it does fine. I replaced the injector again but no improvement. Any ideas? What should I look at next?
  • 3 months later...
    • By Joe Rizo
      Hello All,
      We have exhausted all possible troubleshooting steps, now we are in need of some help.
      Vehicle cranks but will not turn over. Things we have either replaced or tested and are now known good:
      1. Fuel pump (new)
      2. Fuel sensor (new)
      3. Fuel injector (new)
      4. Battery (new)
      5. Spark plug (new), spark tested
      6. fuses (12v to all)
      7. we have 12v at the injector module and 11 ohms resistance
      8. we have fuel in the fuel line to the injector
      9. we have fuel at the spark plug
      10. we have injector pulse, verified with noid tester
      11. brake safety switch tested (couldn't find a separate switch assuming it is using the brake light switch)
      12. seat belt buckled and seat in place (again, not sure if this model has these features)
      13. replaced air filter
      14. replaced several air hoses
      15. flushed radiator and replaced with diluted antifreeze
      16. Drained and cleaned the fuel tank prior to replacing the fuel pump.
      Any ideas, we are open to....Help!!
    • By Rschrem
    • By hetovi
      Hey everyone,
    • By Joe Breaux
    • By Pick a name
      The Axis 500 will not shift into low or reverse.  I have high when it should be in low and all the other places it is reverse.  The gears in the shift cover are fine and I shifted it when the cover was off and yet no change (so it can't be the shifting mechanism gears).  I t has been difficult to get it into low for awhile.  But now it is either high or reverse, no neutral either.
