Not my machine T boss 800 Massimo, < 300 hours will not shift at transmission, cable from selector knob is okay, cannot get it to shift at the transmission. Is there a safety one of the safeties I'm not holding in, I've tried the brake is something weird going on or is it Transmission problems.
