  • 4 weeks later...
Hey @Sando did you get this figured out? I've had a similar problem with my 2022 buck 450. I've checked fuses, fuel pump, spark, solenoid, starter...they all seem fine, so i've been suspecting ECU
    • By Adrian Domingues
      Thanks for your help
    • By Firewalker918
    • By Hoppy one
    • By Eman85
    • By AaronD1982
