MSU 700 Oil Burning
By Geneg
I am actively looking for an oil filter for my Lowe’s branded Axis x550. Lowe’s sold me a spin on filter but every video I’ve seen shows a cylinder filter. Of course Hisun’s website is a year behind not listing anything 2025 and my searches have turned up nothing. Does anyone know what filter I need ( cylinder or spin on) and where I can find one?
thanks
By Joe Rizo
Hello All,
We have exhausted all possible troubleshooting steps, now we are in need of some help.
Vehicle cranks but will not turn over. Things we have either replaced or tested and are now known good:
1. Fuel pump (new)
2. Fuel sensor (new)
3. Fuel injector (new)
4. Battery (new)
5. Spark plug (new), spark tested
6. fuses (12v to all)
7. we have 12v at the injector module and 11 ohms resistance
8. we have fuel in the fuel line to the injector
9. we have fuel at the spark plug
10. we have injector pulse, verified with noid tester
11. brake safety switch tested (couldn't find a separate switch assuming it is using the brake light switch)
12. seat belt buckled and seat in place (again, not sure if this model has these features)
13. replaced air filter
14. replaced several air hoses
15. flushed radiator and replaced with diluted antifreeze
16. Drained and cleaned the fuel tank prior to replacing the fuel pump.
Any ideas, we are open to....Help!!
By barticus73
I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer provided CFMOTO Uforce 600 at $11,500 out the door. Are there any glaring reasons to go with the Uforce 600 at an extra $1000? Is one model more reliable than the other? Any input greatly appreciated.
Thank you,
Jerry
By Rschrem
By Tim n Deb
