I have a 550 colman and i am trying to get running as it came from another military base. It came without keys battery and all fluids drained. So how can i bypass key switch and can i use a temp battery to start it. I want to make sure it runs first before i replace key parts. I added oil, brake, antifreeze still working on other fluids. not sure if i am missing any electrical partsBattery in picture is junk i think. not sure what the connector is. probably will have to buy an ignition cylinder in future. So any guidance is appreciated.
      Is there a way to bypass the seatbelt speed limiter?
    • By Tim n Deb
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By amiracle40995
