  • Alex changed the title to 2018 Kymco 700i UTV Engine Limiter
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By GNFO
      View File Hisun/Axis seatbelt defeat/bypass
      This file is for using a laser cutter to cut a dummy seatbelt tongue to override the seatbelt warning and speed limiter. I used 3mm thick acrylic. My laser is an XTool, so I included the .xcs file for that brands software, but also included a generic vector file .svg. Probably want to verify the dimensions translated properly for your cutter before using. My UTV is an Axis E1, which is basically a rebranded Hisun Sector E1, and I'm also guessing that all the Hisuns probably use a common seatbelt anyway.
      Use only where appropriate and at your own risk.
      Submitter GNFO Submitted 03/10/2026 Category Hisun
    • By Roadstar515
      Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
    • By lmarkie
      I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
      Only problem is the exhaust exit is toward the back seat instead of out the back.
      Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
      Any thoughts?
