Championship Off Road Racing Cancels Final 2008 Race
Newport Beach, CA (November 14, 2008)— Championship Off Road Racing has regretfully announced the cancellation of its final race weekend of the 2008 season scheduled to be held in Chula Vista, California on December 6th – 7th 2008.
Championship Off Road Racing, CEO Jim Baldwin made the following statement:
“The current national financial crisis has impacted our series to the degree that it has become impossible to produce the quality off road racing experience that our fans, racers and sponsors have enjoyed. While it has been our most sincere effort to hold this final event, every possible avenue was exhausted before reaching this difficult decision. Although we have been forced to prematurely end the current season, we are strongly committed to providing the ultimate off road racing experience on the most extreme tracks while continuing to grow the sport. We apologize to our sponsors, teams and especially to our loyal fans for any inconvenience that this has caused. Our commitment to this sport, sponsors, the teams, and fans that support us is unwavering. We will continue to vigorously pursue our objective: To build the most exciting nationally recognized short course off road racing series in the country.”
CORR is in the midst of establishing a solid 2009 race schedule. This confirmed schedule, to be released shortly, is comprised of twelve rounds of racing to be held on six weekends in 2009. There are currently discussions underway with the objective of increasing that number to as many as eight race weekends and 16 rounds. We are working to assemble a revised business plan that will reflect the steps necessary to overcome the current economic challenges. Our sponsors have shown us that they understand the current economic climate and have expressed their desire to participate with us in seeing this sport blossom. The significant investment made in CORR has brought huge crowds, national exposure, and some of the most exciting racing ever seen in the dirt.
http://www.corracing.com/blog.asp?bid=1&pid=227
UTV Industry News
View the full article
  • Popular Now
    • By Rmillerdesigns
    • By schreib69
      I just bought an older (2008) Teryx 750 and am having some concerns.  Hoping of course, that most are not too big. . . but more knowledgeable folks like yourselves will surely have some ideas.  Thanks in advance.
      -- about 2700 hrs, camo version
      -- Starting:  after not running much at the auction site, I tried it and it was tough to start but half of this was likely I did not quite know the tricks for how long to keep the choke on. However, once it started it was kind of hard to keep running until it warmed up(once warmed it starts perfectly every time with no choke).  Now, back to running after the first ignition:  I had to hold the RPM's up a bit to keep it running and when doing so it sounded as if a little gnome was inside the engine pounding on something at random intervals.  Wondering if this could be detonation-- "knocking"?  After warming, it disappeared completely.  Maybe just need higher octane gas??
      -- After starting and running a bit there was a pretty terrible smell, most "like" burning rubber or an electrical fire.  No fire or resolution of this.  Eventually this TOO went mostly away, but still basically present.  Could it be adjustment needed for the main belt variable speed tranny?
      -- When I move from neutral into either Lo or HIGH range forward gears, I get gear clashing.  I did NOT put foot on brake and read in manual(just NOW) that you are supposed to do so.  (I have NOT gotten back out to check and see if this matters. )  OR, could it be part of the drive system is mashed up??!  Geez, hope not.
      -- There is a big open hole allowing direct sight into the belt transmission on the back right side.  This can't be normal, it must require some plastic cover.  Right?  Any rodent could get right into the transmission!
      -- THere appears to be no muffler or spark arrestor unit.  This "could " be the cause of some of the smell. . . ??  but that should not smell like burning rubber or electrical smell. . .
      SO.  That is all.
      I sure would appreciate any insight on this issues and finally(!). . . if I was to take this into a local dealer what would you say are the top three issues I should have them address first?
      thanks!
    • By harleyman2240
      I am looking at buying a 2008 XT700 Arctic Cat side x side.  Are parts still readily available for these (new) or mostly used on ebay? I have looKed up and found several new parts on the web including ebay,  just not sure if this is a good idea to buy the SXS or not. THANKS
    • By mark walkom
