You can post now and register later.
If you have an account, sign in now to post with your account.
I have a 2007 Joyner 1100 sand viper and before it even get's to where the thermostat opens up the oil pressure get's so low I have to shut it down. What could fix this ? I thought about adding an oil cooler with fan, thicker oil, or removing the thermostat. Any advice?
I got the fronts adjusted. I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping. Is there an easier better way? It's like there's too much pressure working against me to be able to twist the height adjusters. How can I relieve that tension to make them easier to turn?
Thanks a lot!
