Hi,
I am in need of a wiring diagram for a 2011 gray wolf 500. I have searched to no end and cannot find one. Nothing comes on when I turn on the ignition switch. Battery is new and the winch works. I did find a blown 30a fuse on the starter relay and thought for sure I found the problem but still nothing comes on after replacing the fuse and the fuse hasn't blown again since replacing it, I have checked every fuse I can find. Bottom line is I am lost and in the blind without a wiring diagram. Any help is greatly appreciated! TIA!!
    • By AlphaSerenity
      Hello,
    • By jertex
      I have two questions:
    • By OBL
    • By mike28honda
