On 7/11/2025 at 7:30 AM, HISUN Sector 750 EPS Failu said:
2020 with 110 hours, we're second owner.
It feels like the differential is skipping a tooth every now and then . . . going downhill, engine braking.
Anyone else doing that?
Now I'm pretty sure it has sheared off a tooth or three in the forward gears.  We do not drive this hard; it's just a ride to the dock and back, and on our private roads.  I shifted into High, and when I touched the gas, it felt like a popped a tooth off a gear.  Then during a short ride it felt like it did in a couple more teeth.
No dealers around.
Any thoughts?
Combining those two posts, I believe the 2WD differential had been missing a tooth in a gear, and every now and then I could feel it skip.  That was when I was going downhill, engine braking, so no power was being put to it.
Then, just by the odds of it eventually happening, when I put it in High the other day, and touched on the accelerator, that gear was exactly at the broken tooth space, so the power sheared off another tooth or two or three.
I had an Ah Ha moment that it might still work in 4WD, if I baby it, because the 2WD differential won't be taking all the force.  That works, but I can still feel the 2WD differential skipping.
Not a very sturdy differential.
    • By Firewalker918
    • By Sidewinder
    • By Eman85
    • By Xov
    • By Timbo
