Need help!!
By rdc
Hope I posted this in the right place. Looking for the left side shaft carrier where the rear bearings go for an 1100cc sand viper, I understand an 800 cc carrier will also work. I need the old style two bearing with the spacer in the middle, the new style with just the one wide bearing wont work. If anybody has one I'll buy it right away. my email is [email protected]
By Mitch13
2022 Coleman 400 with 13 hours on the engine and the mice got to it. Every wire coming out of the steering column in one cluster has been eaten through. I tried reconnecting matching wire colors to each other and I get the left turn signal and hazards to work, nothing else. If I play around a bit I can get the horn to honk or headlights to come on but only when I connect them to the brown wire. Obviously I don't know what I am doing here. Does anyone have a picture of how these wires are connected when they are under the hood on the drivers side coming from the steering column?
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By 180gtr
Parting out a rolled Sand viper 1100. I will list some of the parts I have, otherwise ask me if there is something specific you are looking for. I am selling everything I have for $800. I am located near Glenwood Springs CO.
SOLD ITEMS, I do not have these items.
Wheels
Tires
Engine
Transmission
Axles
Shocks
Control Arms
Things I have....These all came off of the running engine. I have video of it running if anyone needs to verify that.
Throttle Body $90
Starter $150
Alternator $150
Fuel rail, injectors, fpr $100
fuel pump $70
Map Sensor $50
Full set of Guages $150
Exhaust w cat, O2 SOLD
Ignition Coil - SOLD
Wiring harness and ecu SOLD
Radiator, shroud, elec fan, overflow tank $200
Fuel tank w sender $150 Has dent at base of fuel neck, no leaks
I have a box full of misc bolts, nuts, etc.
I will sell the Chassis or Frame alone for $200. The chassis is in pretty good shape, needs some cage repair and 2 areas straightened where control arms mount. If anyone had an automotive frame machine it would take a few hours.
That would include....
Brake calipers, lines, pedal, master cyl, E brake assy,
Steering shaft, wheel
Ignition switch, key
Light bar frame, 2 lights
misc hardware, spindles
2 hubs, rotors
Engine mounts
Throttle pedal, cables
Shifter, cables
Clutch master, pedal
I am sure I am forgetting something.
I am parting this out of ebay right now, I just picked up another project and could use the room. No I will not take less than $700 for all of it or $200 for the frame. I do not need to sell it, I will make far more parting it out but would like the extra space in the garage.
If interested I also have an 07 1000rr engine setup I would sell with the buggy for $650.
By brewski
I just purchased a 2025 kubota rtv 1100 x cab esd esnting to install light bars on the roof it appears to be prewired for lights how do lights mount and what kind of switches do i need
