I have a bobcat UT that will not start.. I have bypassed the key switch. It will not start. I have jumped across the start of solenoid. It will turn over and fire. I understand. This will probably be a neutral safety switch. Does anybody know that if I can bypass this to keep this running?
    • By Hoppy one
    • By mfitzner
      Have spark and fuel pump runs
    • By Jeff freeman
    • By JohnnyB
    • By BWF
      I am at a loss, please help!
      Brad
