I’m helping a friend with a ut400. The drive belt shredded while he was driving it so he ordered a belt and new drive clutch. The new belt is incredibly tight. Even if you spread the driven clutch to install it. So much so that it stalls the machine out if you try to run it once installed. He has ordered another belt thinking the first may have been incorrect. Has anyone ran into this?
    • By mrpro
      I got the fronts adjusted.  I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping.  Is there an easier better way?  It's like there's too much pressure working against me to be able to twist the height adjusters.  How can I relieve that tension to make them easier to turn?
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By MilSurpYinzer
