Buck 50E wont move
By Rusmis91
I’ve never been around Coleman Utv machines. Do they have a good reputation, durable dependability. Could you compare them to yamaha rhinos or Polaris ranger
thanks in advance
By Adrian Domingues
Thanks for your help
By OBL
By Eman85
By Jeff freeman
I have a Coleman 550. Was having problems to start with where it would start and then shut off after a couple tries. It would take off and be good. It then got to a point where it would not start at all. I replaced the fuel injection twice the second time I replaced it I noticed a mouse or something had chewed one of the wires that connect the electrical to the fuel injector. . So two-part question first does anybody have a part number for that wire harness? Second, any other ideas after I fix the wire harness permanently on what could keep it from starting I have gas flow up to the fuel injector.
