I am replacing a wet clutch on my Axis 750. I wanted to add a slug kit to improve performance.  The Slugs I received fit into the holes on the wet clutch, but they are not a tight fit. They fall all the way to the bottom, and when I put the spring plate back on, they will rattle back and forth if I turn the clutch upside down. I don't think they will come out, but if they move freely inside the holes is that a problem? All of the videos I have seen people have to press the slugs in flush, and these definitely float freely. There is not a great amount of space around the slug, but it is moving freely. Thoughts?
    • By AlphaSerenity
      Hello,
    • By mike28honda
    • By mehe
    • By Burk
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
