I have a Massimo t-boss 410 in shop will not start with injector installed, have to hold above hole to get to start , if unplug tps it will run if map sensor is out. replaced ecu, map,and injector.
Still no run, pulled the valve out of throttle body it runs high idle to an idle if out a 1/4 inch, still have hold injecter out to start, but with the valve thing  out you can install map and injector for it to run. what do I need to do.
    • By TapBoss
      So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
      https://a.co/d/09ACQ191
    • By Adrian Domingues
      Thanks for your help
    • By OBL
    • By mike28honda
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
