Coleman UT400 Removing Engine for shifting repair
Go to solution Solved by Butcher6868,
I am trying to deal with the shifting issue this piece of ..... has.
I have the part that Jose made from this video https://www.youtube.com/watch?v=SPU22uKW01Y&t=13s
I have the engine loose except for the drive shafts.  I have no idea how to take them apart from the engine, looked for videos or directions and have not found anything. (maybe I am not using the correct terms when searching)
Looking for help on how to take this apart, so I can lift the engine out and work on it.
I got these instructions from Jose,
  • The engine mount bolts are next and I recommend taking the two bolts on each rear mount out first and then goto the front and remove the long bolt. You may not be able to physically remove it completely as it hits the frame. A little wiggle usually gets it free but is not needed.
  • The rear axle can be pushed rearward and uncouple the driveshaft. Watch out for the spring and note its location.
  • Then shift the engine to the rear an disconnect the front driveshaft keeping an eye out for the spring.
Did you do this? I don’t understand how I can move the rear axle backwards.  Everything is bolted to the frame.  I don’t want to undo all of that also or do I need to?
doesn’t make sense that I can’t take that u joint apart.  Seams to be a much easier solution than unbolting the axle.
Butcher6868, with your replies I am assuming you have fixed your shifting issue with Jose's part.  I got the engine apart so I can get to the piece, but I am having a brain fart and can not figure out how to get the shifting shaft out so I can remove the original piece and weld on the new, what am I missing?
Yes the shaft will have to come out.
    Carefully remove the shift linkage(8mm) and remove it from shaft. Pop the seal out with a pick. This will allow you access to the snap ring retainer clip. Use a set of small snap ring pliers to remove clip and this will allow the shift to remove. Take your time during the mark up process after you have the old bracket cut off. You can cut right across the top/weld. Then knock the bracket off.
  Make sure you hold the forward and reverse gear in place when checking the orientation.
    • By Nick Varnes
    • By Debbie Hogan
      Debbie fm  Texas
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
    • By Rmillerdesigns
