I have a 2022 sector 250 with a side ways engine. Both chain drive gears are missing teeth. The drive gear on the transmission shaft and the driven gear on the chain drive shaft. I have the part numbers but they are not to be found anywhere. My dealer contacted His in and their reply was not available. It was just out of an extended warranty.  Any ideas? I wonder what they would have don't if still under warranty.
    • By nrggaragebuilds
      2004 250DL DIRT DEVIL. Hey y’all, I already know this is a long shot. But I am looking for a the “prick gear” assembly that makes reverse work for my external reverse gearbox. OEM PN D250.08.103 and its assembly. I bought the kart as a basket case, but I saw that the reverse box was present so I was optimistic.  Upon starting working on the buggy I realized there was a block off plate in plate of there the normal gear would be. If my understanding is correct that means the transmission no longer has reverse gear. I figured it’s just a standard bevel gear and I could probably find a gear to make work, but I don’t want to spend the time making all the other housing parts to shim the gear perfectly. Has anyone spare parts, or figured out an aftermarket solution from McMaster? I already know it’ll be a challenge to get this box to be happy again, but figured I would ask
    • By AlphaSerenity
      Hello,
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By dilger
      Transmission vent leaks oil out of it after using
