2013 KAF650 Mule
Howdy! I'm repairing a Mule for my father-in-law and can't find the correct wiring diagram. The 4 wires for the sending unit and fuel pump are attached at the pump, however the other end has been pulled out of wherever they go.
I looked at the fuel pump relay and both fuse boxes, but I can't figure out where the 4 wires need to go. They seem to be long enough to get there. They may have been yanked out of the main harness, not sure how though...
If anyone has the same or similar model, just trace the wires from the top of the tank and let me know where they go!
  • Green_Manalishi changed the title to 2013 KAF650 Mule Fuel Pump Wiring
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Kierobi
    • By Butch
    • By Eman85
