Plow for American Landmaster L5 - Universal?
By Firewalker918
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am at a loss, please help!
Brad
By rdc
By rdc
By Outlaw Redneck
Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando, I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
