Rick
By Sammy
By OBL
By Jeff freeman
I have a Coleman 550. Was having problems to start with where it would start and then shut off after a couple tries. It would take off and be good. It then got to a point where it would not start at all. I replaced the fuel injection twice the second time I replaced it I noticed a mouse or something had chewed one of the wires that connect the electrical to the fuel injector. . So two-part question first does anybody have a part number for that wire harness? Second, any other ideas after I fix the wire harness permanently on what could keep it from starting I have gas flow up to the fuel injector.
By mehe
Now we are looking to you pro ATV riders to let us know if you think your group of people would fit in with ours.
