Does anyone know where the winch fuse is located on a 2021 ut400? I’ve been working on the solenoid because the winch will only go in one direction..
Either in or out depending if I reverse the leads on the solenoid. Now I have no power to the solenoid and it appears I blew a fuse. Winch is supposed to have a 30 amp fuse.
i checked all the fuses in the fuse box near the battery and the 30amp fuse hanging in the compartment. Everything is good there.
but I can’t locate any other fuses. Any help would be appreciated.
  • Alex changed the title to Winch fuse location on a 2021 ut400
Could it be an inline fuse or maybe could be on or near the main body of the winch?
 The best you can do is to trace out the wire and see where it goes.
 You might try going to the their website and seeing if you can download the manual and such and see if it has the electrical schematics?
    • By Rusmis91
      thanks in advance
    • By mrpro
    • By Firewalker918
    • By Burk
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
