2018 Massimo MSU 500. Cuts out at 18 MPH.
By Adrian Domingues
Thanks for your help
By Sammy
By AlphaSerenity
Hello,
By mike28honda
By Nick Varnes
So I have a Bennche Bighorn 500 that I bought used a couple years ago. Was working fine until this winter when I was plowing and I think it drained the battery. And had a difficult time starting and staying running. Idle seamed really low, and would only stay running if I pushed on the throttle. So I changed the battery, and the acm valve, fuel filter and spark plug it will start up and surgery to 3k rpm but comes back down and dies, unless I give it throttle. I am getting fairly good amount of fuel from fuel pump. It does spit at stutter right before it dies. What should I try next?
