2016 Kubota 1100 RTV Title Steering wheel locked
By rdc
I have a 2007 Joyner 1100 sand viper and before it even get's to where the thermostat opens up the oil pressure get's so low I have to shut it down. What could fix this ? I thought about adding an oil cooler with fan, thicker oil, or removing the thermostat. Any advice?
By Skeeter22
By jertex
I have two questions:
By AaronD1982
By HighSon
Locking gas door.
Rear view mirror.
Lowered and modified headrest bar for improved rear view. Tailgate protector.
Folding armrests.
Overhead utility rack. Keeps the interior cooler and dryer, too!
Folding rear seats.
If anyone wants links to the rear view mirror, seats, or arrests, let me know and I will post. But know that everything requires some level of fabrication. The utility rack was all custom built. Cheers!
