thanks...pa
    • By OBL
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
    • By chadd
      Hi all, i have a 2021 gc1k  with the tbg eng, and i am needing frt cv axles, on a review of a oem intimidator axle on ebay the buyer stated that they were exactly the same as a 08-12 rzr 800? Has anyone else ran into thiz? When i look at the 2 side by side the only diff i see is the inner joint of the oem axle looks exactly like the outer joint,but the rzr axle inner joint has the slide deep cup?
    • By mehe
    • By Jody Deville
      I’m looking to best place to buy replacement axles for the rear in my buggy. Both axles are bad. Where is the best place to find them?
