    • By paul allen
      thanks...pa
    • By AaronD1982
      I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV.  It ran fine for a couple days but the low battery light was flashing while it drove.  It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn.  It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway.  Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit.  Fair enough, let's just order a replacement solenoid, right?  No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin.  How do I swap that and make it work?  Can I even?  Where do I find correct parts in the future?
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
