Possible trouble point to keep an eye on
Popular Now
By Fmaxiron
Thanks a lot!
By Rmillerdesigns
Hello. I have a 2016 Massimo MSU 500. I was putting on a lightbar and i screwed up and didn't disconnect the battery so when i was taking of the positive cable to put on the power from the lightbar it sparked and now the utv has no power. I turn the key over and all i hear is a chirp. No lights or anything. Everything that comes from the battery to the jumper box up by the battery shows voltage but anything coming out does not such as to the winch or anything like that
By Surfalia
Just purchased this Old Hisun and it included with a box with a brand new EPS kit. I found YouTube University installation videos and it looks doabke, but maybe the kit is made for newer models because mine doesn't have any extra open plug and play wires I see in the videos that woukd allow me to seamlessly connect the EPS wiring harness too. Has anyone ever retrofitted an EPS kit to a 16 year old model?
Thank you for any usable input offered.
Sincerely,
Surfalia
By Sylvain Gravel
Hi,
I have an Axis 500 2022, here's my question. Is it normal that there is a gap of a few centimeters when I press the gas pedal before the engine increase speed, as if there was a looseness? Therefore I would not have all the power.
Thanks.
By lmarkie
I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
Only problem is the exhaust exit is toward the back seat instead of out the back.
Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
Any thoughts?
