2025 Amp Crew Ranch Edition range issues and questions.
By rdc
By Xov
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By Stan M
I just received my 760L a couple of days ago and it's been difficult to shift between gears from the get go. At first I could rock the unit and it would free up for a while but now it's just stuck in reverse and rocking doesn't work. I had the UTV delivered directly from Massimo and there aren't any service centers in my area. Any ideas? Thanks
By Terry B
We purchased this UTV less than 60 days ago and now I am having issues with drained battery. Used UTV for about an hour then stopped and when I went to start back up my battery was to low to start it. Jumped it and it started right up and ran fine back home. Tested charging and it’s not charging while running. Can it be anything other than the stater??? Can I look for something that I can fix Quik or does it have to go to the authorized service center to stay under warranty? It will take some time to get it in and out of service
