Polaris Ranger 1000XP steering issues.
By Firewalker918
By Alex
What’s Included?
Why the RANGER XD 1500?
Entry Information
By rdc
By Rmillerdesigns
By a4x4nutt
2021 uforce 800 turning radius is awful .
I just bought it added perfex lift
And 1.5 wheel spacers
The turning radius was bad before the lift .
I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
Are the stops inside the steering rack ? Is there a replaced steering rack with longer throw to curb this issue ?
Any suggestions?
