2022 landmaster l7x jumps to idle after driving
By techmech92
The company I work for bought 4 Landmaster L4's. They have been here for about a year; I am the tech that works on them. One started bogging down under anything over half throttle, I checked everything I possibly could think to check before finally breaking the engine down and find that the intake cam was worn almost completely to no lobe at all. Last week another unit started running poorly until the throttle no longer responds. I can't seem to find anything that would make this happen, I am working on having the company obtain a tiny scan to be able to access any fault codes, but so far everything electrical seems to be doing what it should be. They both have the Vanguard engine. Any tips to figuring out the one, and tips or tricks to help me keep the other running?
Thank you for your time.
By Silent3923
Been waiting over a month and a half for a transmission from bobcat, they claim the polaris transmission is different. Can anyone verify that???
By Nick Varnes
So I have a Bennche Bighorn 500 that I bought used a couple years ago. Was working fine until this winter when I was plowing and I think it drained the battery. And had a difficult time starting and staying running. Idle seamed really low, and would only stay running if I pushed on the throttle. So I changed the battery, and the acm valve, fuel filter and spark plug it will start up and surgery to 3k rpm but comes back down and dies, unless I give it throttle. I am getting fairly good amount of fuel from fuel pump. It does spit at stutter right before it dies. What should I try next?
By BWF
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
By Fmaxiron
Thanks a lot!
