Hand brake
By Rmillerdesigns
By Timbo
By Guest
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
By redneckred
After replacing a master cylinder on this machine, I was bleeding the brakes and discovered the brake line that connects to the rubber hose coming from the master cylinder under the seat and turns into a small tube going to the back brakes appears to be leaking at the joint. I checked the connections and found them to be tight. I was looking at getting a replacement part, but can only find parts for the front brake line hose to the calipers and not anything from the master cylinder back to the rear hoses. Does anyone know where to find this part or what the part number actually is? Not sure if I can fix the leak and I am not a brake hose rebuild guy, never had much luck without them leaking.
