This is my first UTV and it ran great the first 500 miles. Then it slowly got harder and harder to start. Now I have to keep giving it gas when I first start it for about 1 minute until it will idle by itself. This past weekend I took it on the trail and it died 15 minutes into the ride and lost all spark. I got towed home and tried to see if I had spark the next morning which I did and it started but died 10 minutes later. Anyone have any ideas what I should do or check? Anything would help thank you!
  • 2 months later...
  • 1 year later...
Any help would be appreciated. I have a 2015 strike 1000 crew I just bought and it was hard to get it started. Having to pump the gas and rev it several times to get it to idle. I pulled the fuel pump to check for and clogs or dirt and when I put the pump back in now it cranks easier and idles but lost all power. Barely reaches 20 will no spin a tire on dirt.
    • By AlphaSerenity
      Hello,
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By mike28honda
    • By Nick Varnes
    • By Hoppy one
