Does anyone know if there is a interchangeable steering rack that would work from other brand of sxs
Are a rebuild kit to replace the bushing.
Mine is a 2015 Dominator 800 2×
The steering rack outer bushings are gone .
I didn't have to find new bushings anymore. We went riding a couple of weeks ago and pretty rough trail.Long story short it the already damaged rack and bracket ended up getting torn off and broken the rack.
I ended up getting a rack for a Polaris rzr off Amazon for $59.00 and a EPS for a Ace Polaris from Super ATV on sale for.$169.00  I adapted them to the Dominator going to finish up the work tomorrow night.
  • 4 weeks later...
Finally got it out on the trails a couple of weeks ago. The power steering worked great and the 30" tires, and the fox shocks it not like same machine. Very enjoyable to ride now. Very smooth.
A update it's worth every modifications I have done. I would do everything all over again.  It very smooth and climbs hills and going over Rock's and logs so much better.
    • By Tim n Deb
      Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
      Thanks for your input
    • By CaptainMorgan
      I have a Bobcat 2200 Diesel (built by Club Car) with a 2-weight Team Primary Clutch I want to rebuild, possibly replace. The clutch has an annoying rattling sound at idle and appears the rollers and weights are worn and loose. When I opened it up, everything looks clean and in great shape. It's just that all the moving rollers and weights seem to have way too much play in them, possibly causing the noise. I've searched for clearance and torque specifications with no luck at all. The UTV has less than 500 hours on it.  Any ideas?
    • By Kevin Ullman
